S95160 TFT-LCDs Made in China phone is being used in perhaps the market’s are the TFT module diagram and source code can be useful also scheme similar TFT LCD screens you can use the module SD Card Connection looks uvision2 Keil prepared by the master code and library files there.
S95160 datasheet schema code and files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-17491.zip
Publication date: 2011/10/30 Tags: microcontroller projects
PIC18F2550 8 axis joystick for Flight Simulator
8 axis joystick circuit flight simulator designed to be used on computers running simulator programs can work with flight simulator info because I have so I can not discuss, but the person concerned useful to the applications which can be also different control projects may work in the project’s source CCS C (+ ppm_usb_hıd.h) codes There eagle pcb drawings and diagrams.
