2X100 amp circuit other transistor amp based on slightly different output NPN-PNP transistors instead of just NPN type is used quiescent current adjustments to not need to do (fixed) I am sure many, including people found this setup process does not like 🙂 printed circuit board PCB layout have been successful in addition to tone control and feeding solids collected on a single pCB.
2x33v ac dc operating voltage of the circuit 2x46v 300w output voltage of the transformer can use it for 8 ohm speakers are 4-ohm speakers to be used on a larger cooler should be used or even fans should keep a low supply voltage ..
Source: videorockola.com/sonido_e_amp200w.php
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18727.zip
Published: 2012/03/23 Tags: audio amplifier circuits, transistor amplifier
ARM Digital Power Supply Circuit STM32 Nokia3310
Digital power supply circuit based on voltage-current information stm32f100c4 arm nokia 3310 lcd via an lcd menu system also have detailed gürüntüleniyor the output voltage can be set via the menu, including contrast, current, flash or memory can be on the record. STM32 ARM programming, especially for people dealing with a good example to all source code files in the shared library files in pcb, schema, etc.
