MOSFET 400W Stereo Power Amplifier Circuit irfp9240 irfp240 Proteus isis
| July 27, 2024 Updated
Amplifier 2x200W power MOSFETs in the circuit used irfp9240 irfp240 and symmetrical power supply voltage + – 50v and 200 watts rms 4ohm speaker gives you the power. A sense of calm with current adjustment potentiometer 4.7k from 100 … 200 to be set. Diagram, pcb printed circuit board, layout drawings and isis proteus simulation files there.
400W Power Amplifier Circuit
amplifikator-proteus-isis-mosfet-amfi-simulasyon-120x120
Source: forosdeelectronica.com
Published: 2010/08/11 Tags: ,
1 Comment “MOSFET 400W Stereo Power Amplifier Circuit irfp9240 irfp240 Proteus isis
    Burned Transistor Capacitors, Resistors
    I generally various trials also material loss data, but this business of entertainment into a Getian those have high current, high voltage capacitors with resistors, LEDs, transistors, a lot like the electronics swings are burning 🙂 a computer motherboard used in the ram burned has interesting displays ..
