RGB led show PIC12F675
| Updated on September 3, 2024
Hello Electronic lovers that I have done it again with you in this article is an applications often wanted to share. In this study, using the PIC12F675 and 74HC595 Entegere be moved sequential RGB light with a very nice splash of color emerges.
Isis video of the application circuit and the hex code is available in the attached document. Friends who are interested let you go.
PICmicro Connection example 74HC595
74HC595-pic16f628
PIC12F675 RGB LED Test
RGB led show PIC12F675 proteus isis simulation, pcb and source code files:
Publication date: 2010/12/12 Tags: , , ,
1 Comment “RGB led show PIC12F675
