Beautiful Decor PIC12F629P RGB Led Lamp Glass Globe
| Updated on August 3, 2019
An application known as the bottles in the RGB DIY Mood vases made by placing different RGB led effect circuits, especially in the dark, they look very nice decors. The author has placed the glass sphere into the RGB driver circuit with all the details of the project, told the project belongs to the files with the hex codes and pcb asm source schema drawings.
Using the microcontroller on the circuit PIC12F629P 9 single-color LEDs 5 mm led (ultra bright transparent) mixed used, burning times with RGB effect is provided. Insert into different things, the circuit around different decors available..
rgb-led-pwm-driver-rgb-led-mood-light
Source: picprojects.org.uk/projects/rgb/index.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18834.zip
Publication date: 2012/05/01 Tags: ,
1 Comment “Beautiful Decor PIC12F629P RGB Led Lamp Glass Globe
    2SC5200 2SA1943A Amplifier Circuit Pioneer 200W
    200W amplifier circuit Pioneer (Pioneer-PR-200N) is an old sound system versiyorun pcb printed circuit board design is quite small clone 5w 0.22 ohm resistors have been under a lot of savings from the card this way, monta has been the highest working voltage of the circuit +-symmetric 50v power drop considering the 35.40v with çalıştılabilir. 200 watt amplifier circuit on the pcb, there is a list of the schema diagrams and materials.
