RGB LED project precise color settings will work a program visually RGB color codes in hex gives # define the software can be included in 16bpp and 32bpp pixel options, as well as the color depth can set up .. RGB to HEX Converter program without requiring installation directly able to run .. RGB HEX Converter Program
Source: thaieasyelec.com program:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19061.zip
Publication date: 2012/06/11 Tags: electronics software tools
PT100 Sensor Thermostat Circuit ATmega8
Thermostat circuit for 2 pt100 temperature measurement used atmega8 mikrüdenetleyici sensor pt100 sensors gives the circuit output is being used according to the information received. The thermostat is located on the circuit board led display temperature value. Connect the relay outputs can be controlled by a variety of devices, TRIAC, etc. PT100 sensor, Thermostat for the project in the c source code and eagle pcb, schema drawings.
