New project based on PIC16F877 lm35dz temperature sensor and receive information we display on lcd graphics … LM35DZ temperature sensor-55C to +150 C temperature ölçebilir.lm35dz 10mV per degree of temperature sensor generates energy. 1C = 10mV = 1V voltage while the 100C is üretir.lm35 analog temperature sensor.
PIC16F877 LM35DZ Temperature Meter Schematic
Proteus isis code files to the project and the proton ide (LM35.PBP, lm35.bas, GLCD4.DSN, LM35.HEX etc. ..):
PIC16F877 LM35DZ Graphic LCD Temperature Meter Proton ide
Published: 2010/01/02 Tags: microchip projects, microcontroller projects, pic16f877 projects
Change the Direction of DC Motors with Toggle Switch
Occasionally I use a simple method, many people do not know recently an ab dc motor driver asked what would be used to ask when I left or right engine to change the direction said that a circuit is not necessary to’ve told you many our simple Although it seems inform have benefits.
First, we will use the key tell you about happening in the market with the name known I do not know, I two-position switch or button my skin is open part are short-circuited turned off other parts of the short-circuited to change motor direction we can use for key six-legged in English “Toggle Switch” is mentioned as
