Nokia LCD Models Proteus isis Examples Circuits Library
| Updated on September 6, 2024
Nokia lcd screens, pic, atmel microcontrollers used in this project, with a lot of other job so popular as talking about the proteus simulation model for the program, set up a virtual environment, try the library files created circuit
isis-nokialcd-demo-circuits-pic18f-atmel
isis-nokia-lcds-proteus-vsm-models-nokia-6610-ciruit nokia-1100-lcd-demo-circuit proteus-isis-nokia-3530-lcd_demo
Nokia: 6610, 6100, 3530, 3510i, 1100, isis can work with LCDs. S1D15G14 drive of the 3530/3510 6610/6610i/6100 sürcül PCF8833 PCF8814 1100 is a driver. Also isis hex file with simulation and application circuit there are a lot of examples.
Note: LIBRARY and MODELS proteu files in the folder where you installed section will take into folders with the same name generally; C: \ Program Files \ Labcenter Electronics \ Proteus x Professional will be installed in the directory but the files within the folder NOTICE Please be copied to the folder with the same name.
Source: http://projectproto.blogspot.com/2010/11/nokia-lcds-proteus-vsm-models.html Alternative link:
Publication date: 2011/03/12 Tags: ,
1 Comment “Nokia LCD Models Proteus isis Examples Circuits Library
    5V DC to DC LM2576-5 Step-Down Regulator Circuit
    LM2575 is quite popular in many applications use shared circuit 5v 1 amp output is crafted with a quality printed circuit board drawing of the eagle got engaged at the end of your name that used the sheath to263-5 LM2576-5 States that the same output voltage the output voltage can be adjusted with the “adj” version of the chip.
