Model files for the power supply set in the Proteus electronic simulation program (PROTEUS variable dc source). There are two models of Proteus Variable Power Supply. Variable voltage source controlled by a dial. Proteus Adjustable Current limiting Linear Power Supply
Proteus Adjustable Power Supply Library Requirements for the model to work:
The model’s .dll file needs to be copied to the ‘MODELS’ folder of your Proteus installation or be in the same folder as the project file that uses the model.
To add this model to your Proteus library:
– Open the demo diagram (.pdsprj file)
– Right click on the model and select the ‘Make Device’ command
– Click ‘Next’ until you reach the last page of the wizard and then click ‘OK’.
Source: classic.dizzy.co.za/proteus_downloads.asp
Publication date: 2024/03/16
After I added this to my library, my Proteus 8.8 keeps turning off or shutting down every 2 or 3 minutes….What could be the problem.
