Professional Eagle CAD Designs
| Updated on December 17, 2024
There are interesting projects but I don’t think most of them will be implemented. For this reason, I touched on PCB, Schematic designs. Especially power electronics studies can be useful for you and you can get inspiration. Some projects have also been made with large, detailed PCB designs.
Sine controller for brushless motors. 24 cells – 60A – Torque or Speed ​​control unit. 1 Vss encoder at 0 rpm for analog or pulse input, HIPERFACE, torque
Sine controller for brushless motors. 24 cells – 40A – Torque or Speed ​​control unit. 1 Vss encoder at 0 rpm for analog or pulse input, torque
Encoders for brushless motors with signal outputs for commutation and speed control. Also included as a 1Vss version for download sine regulator.
2 x 32 W and VF display compact tube amplifier. Control CPU for signal functions.
2 x 12.5 W and VF display compact tube amplifier. Signal function control CPU.
Controllers for brushless motors. 24 cells – 40A – Torque or speed control unit. Analog or input, opt pulse. Incremental encoder at 0 rpm, torque
Inverter 1400VA, 3.5A 850W, 1.0-200.0 Hz motor power up to 230V power supply
Sine wave inverter 100-230V / 0.2 A-3, 0A 48Hz-~ 62Hz. Active power and cosPhi measurement. Overload factor 2 12V input.
Current source 0-24V / 0-80A / 999W. With ballast circuit for feedback energy.
Using this circuit, the output data of the company Sylvac and measuring instruments can be read.
Tektronix TDS500 Series Oscilloscope, TDS600 TDS700 and RS232/Centronics interface.
Copy of USB card Tasmanian Wolf. Compatible with front slot on GBA1000 motherboards, but also possible to use on all Amigas with Zorro II slots.
Turbo card revision for GBA1000 motherboard. Support for MC68040 and MC68060 processors. 64-128 MB SDRAM on board.
32 MB memory expansion for GB A1000 motherboard. Built to 4M x 4 DRAMs. Memory volume about 15 MB / s 32-bit data bus width.
Village Tronic Picasso II graphics card copy. Functionality is limited compared to the original. For GB A1000 motherboard.
Motherboard for Amiga1000. 68030 processor with 50 Mhz. 2MB Chip RAM, 8MB SRAM, IDE controller, Flicker Fixer clock.
Copy of A2320 Display Enhancer by Commodore. Matched Amiga A4000 assembly conditions with 24 bit color depth.
Amiga 1000 Phoenix Turbo card. 68030 and 68882 FPU. 25-50 MHz operation. Automatic configuration and 512 kB Flash ROM 8 MB RAM,. Bootloader Turbo IV
sine-controller-for-brushless-motors-24-cells-60a-torque-and-speed-control-unit
brushless-with-signal-outputs-for-commutation-and-speed-control
compact-tube-amplifier-with-2-x-32w-vf-display-control-cpu-of-signal-functions
inverter-230v-power-supply-up-to-1400va-35a-850w-10-2000-hz-motor-power
Professional Eagle CAD Designs dw link
Publication date: 2024/12/17
