MicroC LED Blink Example PIC12F675 Police Lamp Strobe Flashing Circuit
| September 14, 2023 Updated
In this article microcar hello friends with you in a simple way with the police emergency lights in the form of a burning light I offer project. Microcar, which features extensive use of a compiler. Entirely in C language-based structure. Anyone who knows C can be easily adapted. With little change in the program, such as Hi-tech c compiler can be used in protonc Picbasic.
12F675 can be found very easily in the market and how we can do this work I present to you in an understandable manner. (For anyone who knows the basics of the C language is very easy to understand.)
To work on a small scale with the number of unnecessary pin PICs to be wasted, I believe it is desired to use of PICs.
Police Lamp Flashing Circuit
polis-lambalari-kirmizi-led-mavi-led-isis
Creating a project in MicroC
microc-proje-olusturma-new-project
microc-proje-olusturma-new-project-2
To create a project with 12F675 PIC, external reset must be turned off.
INTRC… to use internal oscillator. Chosen.
Watchdog closed…
Police Lamp Strobe Circuit schematic and microc code files:
Published: 2010/02/20 Tags: , , ,
1 Comment “MicroC LED Blink Example PIC12F675 Police Lamp Strobe Flashing Circuit
    Animated LED Advertising Signs Circuit
    Hello friends with you in this article are made using basic and simple method JAL language written with the animation project I offer LED advertising.
    Nowadays, the increasing human needs require more advertising and more attention to the low cost of advertising signs withdrawal is requested.
    Complete at this point is that LED technology to the rescue. Now the LED colors can be found in every shade of color. LED letters prepared in the desired size and shape is drawn directly burned. But tons of people moving or changing objects of interest in light of the results of some research that is more. Here in this letter is born out of the need to built a variety show with animations.
