PIC32 Spectrum Analyzer Circuit TFT PIC24 PIC32 Examples
| Updated on August 3, 2019
Spectrum Analyzer application PIC32 series from PIC32MX360F512L performed by imaging the 3.5 TFT LCD (16.7m. Color) 320X240 screen using software Microchip MPLAB C32 compiler prepared with ssd192x driver (SSD1928L Drivers) includes all the source code there is also the FFT aligrot the code through’s. The project was carried out in this module by module scheme LVC75Z779 there (no PCBs) analyzer to test the computer’s sound card, MP3 player or other audio source can be used.
PIC32MX360F512L Spectrum Analyzer implementation of the material terms can lead to difficulties, but the source code driver files for different projects is very useful also PIC24F series for the 2.4, 2.8, 3.5 TFT LCD and have different applications, all of the source code and drivers are available and used PIC24F experiments set schema, there
audio-spectrum-analyzer-fft-pic32-proto-board-pic32mx360f512l
Manufacturer of the need to appreciate very well prepared with plenty of documentation, for example, as well as knowledge of the scheme also gives set of experiments
source: techtoys.com.hk alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19751.zip
Publication date: 2012/09/14 Tags: ,
2 Comments “PIC32 Spectrum Analyzer Circuit TFT PIC24 PIC32 Examples
    Atmel ATtiny45 Bluetooth Scoreboard Circuit
    The scoreboard circuit is based on Atmel microcontroller ATtiny45 circuit cell phone can be controlled via bluetooth, the bluetooth module used in the indicator circuit BTM400-6B is an LCD TV has VGA output of the circuit for the project and Android Bluetooth communication codes Scoreboard attiny45 eagle pcb, there is a very useful resource schema diagrams
    Note: the library does not have schema attiny13 attiny45 used eagle looks microcontroller attiny45
    Bluetooth Scoreboard This project aims to display a scoreboard in a regular VGA monitor, remotely controlled with an Android device (cellphone, tablet) via Bluetooth. Bluetooth module BTM400-6B will wait for a connection from a device (e.g. an Android phone) and will act as an Serial Port Profile re-passing everything received from the device to the UART interface. In our case the ATtiny will read the data but won’t “speak back” to the module, so it’s really a one way communication from that point of view. pretty simple: control a ping-pong electronic scoreboard
    PIC 32 Spektrumanalysatorschaltung TFT PIC24 PIC32 Beispiele
    Spectrum Analyzer Anwendung PIC32 Serie von PIC32MX360F512L durch die Bebilderung der 3,5 TFT LCD (16,7 m Farbe) 320X240 Bildschirm mit Software Microchip MPLAB C32 Compiler vorbereitet mit SSD192x Treiber (SSD1928L Treiber) enthält alle Quellcode gibt es auch die FFT aligrot der Code durch . Das Projekt wurde in diesem Modul durch das Modulschema LVC75Z779 dort durchgeführt (keine PCBs), um die Soundkarte, den MP3-Player oder eine andere Audioquelle des Computers zu testen.
    PIC32MX360F512L Spectrum Analyzer Umsetzung der Materialbegriffe kann zu Schwierigkeiten führen, aber die Quellcode-Treiber-Dateien für verschiedene Projekte ist sehr nützlich auch PIC24F-Serie für die 2.4, 2.8, 3.5 TFT LCD und haben unterschiedliche Anwendungen, alle Quellcode und Treiber sind verfügbare und verwendete PIC24F-Experimente legen dort das Schema fest
