PIC18F4550 USB Marquee Display Scrolling Text Circuit LED Visualbasic
| Updated on August 5, 2024
Scrolling text circuit displays the text sent via the computer’s USB port. The program used to send text has exe and source codes prepared with visual basic. The circuit is based on PIC18F4550, 8×32 dot matrix LEDs are driven by 2 74hc154, and the pic software is prepared with proton ide.
Marquee LED Display Scrolling Text LED Circuit
pic18f4550-vb-isis-usb-8x32-dot-matrix-led-leds-74hc154
author: @Eyüp – Source: Usb-8×32-kayan-yazı Computer controlled Marquee Displaying Circuit files Alternative link:
Publication date: 2010/11/20 Tags: ,
1 Comment “PIC18F4550 USB Marquee Display Scrolling Text Circuit LED Visualbasic
    BCD Decade Counter Simulation 74LS160 Example Circuit
    74LS160 integrated circuit prensbini a beautiful work to understand the circuit. the chip integrates a signal is applied to the rising edge of the clock input, four output of 0-9 count. every rising edge when a growing, including MultiScan output output by taking the exit number 15, leg nine more 74ls160 can be connected in series to each other.
    BCD Decade Counter 74LS160 Example Circuit
