Terrarium Control CCS with PIC18F2550 and PIC18F2520
| Updated on July 7, 2023
Two interesting projects Inverer the-PIC and Terra PIC terra abviously with pets or aquarium cabinet temperature of the light feeding control enables Inveria the air control may be associated with exactly can not bring my project to publish reasons CCS prepared with source code and Orcad files that I did not understand my PIC Programming could be useful for dealing with our friends. Isis also came prepared with layers of simulation files in the library’s code a project that will benefit in every way
This project, which I have served as project purpose career consists of a controller for automatic terrariums, is thought to regulate temperature, humidity, hours of light and water to create a perfect microclimate for any reptile and with a few adjustments can be adapted as a controller for small greenhouses
The project will include the schematic design and pcbs, as well as the source code in C for the PIC 18F2520, documentation and a couple of videos of the system in operation.
terrapic-code-in-C-for-the-PIC18F2520
Source: www.hobbypic.com Terrarium Control with PIC18F2550 PIC18F2520 CCS C files:
Terrarium Control CCS with PIC18F2550 and PIC18F2520 dw link
Publication date: 2008/04/03 Tags: , , ,
1 Comment “Terrarium Control CCS with PIC18F2550 and PIC18F2520
    100W Darlington Transistor Amplifier Circuit with BDW83D BDW84D
    Technical Specifications – Characteristics: Output power (f = 1 kHz, d = 0.5%): 100 W into 8 ohms
    power Supply voltage:.. 40 V Quiescent current:… 50 mA Maximum current:… 2.6 A Sensitivity: 600 mV .. Frequency response: 10-35000 Hz …. (-1 dB) Distortion HD:…… 12:01% Intermodulation dist.:… 0.02% to Signal / noise: ….. 83 dbconstructio the
    Quiescent current setting
    + Connect the ammeter in the supply circuit section Anfi Circuit idle (without connecting speakers) potentiometer P1 until the current drawn is 50mA ayary must be a value close to the full value
    total 80v ​​dc dc supply voltage of the circuit 2x40v Be careful 1k potentiometer P1 is done with sense of calm setting will be set to 50mA
