These sorts beautifully made with PIC18F2550 applications with source code showing up there all three projects associated with computer software assembly pic is computer software written with Visual Basic 6
PIC18F2550 USB oscilloscope
Dc.sinyal 1 kHz maximum sampling analog input 3 sections may be doing more than the maximum 5-volt input circuit can cause damage to your computer, be careful
PIC18F2550 Usb voltmeter, frequency counter
More than the maximum input voltage of 5 volts circuit and may damage your computer, be careful
PIC18F2550 USB Thermometer
PIC18F2550, usb osiloskop, usb termometre, usb voltmetre, visual basic usb
source: http://www.moty22.co.uk/ Pic18f2550 USB Apps. circuit and code files alternative link:
Publication date: 2010/04/27 Tags: microchip projects, microcontroller projects, pic18f2550 projects
TV Remote Control Decoder Circuit with PIC16F628 Visual Basic
Remote control decoder circuit PIC16F628 controller based on the control signal is produced with computer software, visual basic 6 controls the data decimal, binary displays on the program. Prepared with PIC16F628 assembly source software. Asm code and source code in Visual Basic 6’s.
Circuit computer via serial RS232 port allows communication with the PIC supply via the serial port IR Senri and retrieving with regilat 78L05.
PIC16F628 TV Remote Control
