4 Channel USB Fan Control Circuit PIC18F2550 LM335Z
| Updated on August 3, 2019
Fan control circuit on a Board of Directors established the computer control program through Pic18f2550 microcontroller 4 channel can be set independently of the rotation speed of the fans is connected. Temperature sensor is used as LM335Z. The program’s work for Microsoft. NET framework 3.5 must be installed already the program installation files downloading USB fan control software with Visual Basic Express 2008 installation and source files.
If the Microchip C18 Compiler microcontroller Software Lite with pic18f2550 prepared hex and given C source kdları
Note: the Fan control circuit used in standard pc vaults can be connected to the cpu fans or oğutucu fans (100-250ma)
The Intelligent Fan Controller is designed to control the noise generated by the fans inside your computer. It does this by varying their speed based on temperatures measured inside the case. When it is cool the fans will run slowly and they will only speed up when needed… when your computer is running hot.
Anyone with a noisy computer, especially a Media Centre system in the lounge room, will benefit from this project. After installing this device, my computer is now so quiet that I can hardly tell that it is running – and that is a blessed relief.
The main features are:
Configurable speed control based on temperatures measured inside your computer
Control up to eight fans and measure up to four temperatures
USB interface and Windows software for setup and monitoring
It will run independently without the Windows software (once it has been configured)
intelligent-fan-controller-monitoring-pic18f2550-usb-lm335z
source: geoffg.net/fancontroller.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19566.zip
Publication date: 2012/08/27 Tags: , ,
1 Comment “4 Channel USB Fan Control Circuit PIC18F2550 LM335Z
    SMPS Switchmode Power Supply Design Program
    Switchmode Power Stage Designer SMPS Switchmode Power supply design program, buck, boost, inverting buck-boost, Sepic, flyback, active clamp forward, single switch forward, two switch forward, push-pull, half-bridge, full-bridge, weinberger SMPS for various types of inductors, transformers giving details.
    Also suitable for use in the calculation of an integrated control, duty cycle information, etc.. suggestions there is The
