Ultrasonic Sonar Radar Robot SAA1027 PIC18F2420 FT232
| Updated on August 3, 2019
PIC18F2420 microcontroller board radar robot project for detection msu05 ultrasonic sensor module this module is used instead of the alternative ultra sonic by adding other modules or op amp amplifier circuits, 40 kHz ultrasonic sensor can be used. SAA1027 motor driver IC stepper motor driver is being used on the floor of the computer connection is USB interface FT232 used
Sonar Radar Robot project program (java xp32bit-64 bit and linux) has been granted, together with the C software source codes, pic18f2420 schema and pcb files.
Scanning Sonar robot Scan sonar is a robotic tool for visualization of the environment of a mobile robot. A sonar sensor motor, allows to have an ultrasound image on the screen of a computer. This scanning is carried out over 180 °. A good knowledge of electronic circuit design is an asset for the realization of sonar. C programming concepts and Java can adapt to the needs of this implementation designer.
ultrasonic-sonar-radar-processor-saa1027-ft232-electronic-circuit-pic18f2420
Source: d.nardi.free.fr/sonar/general/toc.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19589.zip
Publication date: 2012/08/26 Tags: ,
1 Comment “Ultrasonic Sonar Radar Robot SAA1027 PIC18F2420 FT232
    Ultra Sonic Cleaner Robot Circuit L298 AT89C2051
    AT89C2051 microcontroller used in robot motor drive for cleaner L298 dual H-bridge driver IC is used 40 kHz ultra sonic senrörler (multicomp sq-40-t-10b) to detect and to change direction with the bodies, continues to the Road Blocker is a professional robot vacuum cleaners sold in the market for an example project to detect or prevent robots
