Hello
In this article we will talk about Making Voltage Probe. First, let me explain what is the voltage probe. Voltage Probe, displays the amount of voltage at one point. In addition to a digital value, may include features such as logic states.
We will do a digital voltage probes made with the PIC18F242 Voltage Probe. To measure the voltage of the built-in PIC 10-Bit 10-Bit adc’s the kullanacağız.ancak not as I’ve used the 8-Bit.
Value of the voltage on the LCD digital and analog displays. LEDs show the value of the corresponding logic.
Because I use crystal oscillator circuit simulation. Circuit the oscillator OSC and OSCOUT a general connection between the terminals can be established.
ISIS simulation and source code are attached.
App of the isis proteus simulation and C code files:
Published: 2011/01/03 Tags: microchip projects, microcontroller projects
Robot Development Robot Control Board for your Robot Projects
ROT-KON-1.0 is a general robot control board. Most of what we want with ROT-KON-1.0 robot is designed according to the project. ICSP connector on the program include throwing socket and bootloader. Also Aport male connector portion is connected sequence of sharp GP2D12/GP2D15 sensor is designed according to the sequence of the pin.
