Remote Controlled Toy Car Project PIC16F877 PIC16F628
| Updated on July 12, 2023
software CCS used N channel FETs with a 60 amp motor drive circuit and used for different applications control circuit PIC16F877 24c08 eeprom and ICL7660 used CCS EEPROM communication with examples of how you can also control circuit MC33063AP made ​​with dcdc converter circuit and 5 .12 v input 12 … 19v output 12 … 18v input 28v output short, you can get enlightened or different project ideas that could
24c08_pic16f877_pic16f628_robot
Technical data of the controller
* Control Unit – the heart of a PIC16F628 by the company Microchip
* N-channel FET amplifier – bridge circuit with Motorumpolung and / or brake
* Input Voltage – 6 to 10 cells or 7.2 V to 18V
* Second peak electricity: 100A (depending on the type FET)
* Current: 60A (depending on the type FET)
* Internal resistance: 0.004 ohms constructed
* 1.5 A (only briefly, because no cooling)
* Under voltage detection
* Easy leveling with the remote control
* The tax needs to stick to neutral stand
* Monitoring of the recipient signal
* Current limit independent pre-trip ticket – Adjustable 5A in stages from 5A to 75A or without limit
* Adjustable parameters (now optimized for car models):
* Clock frequency – Switchable between 1900 Hz to 3900 Hz
* Delay Current limit for the start with an adjustable acceleration lag (slow start) adjustable delay
* Delay Current limit for driving with an adjustable delay acceleration of an adjustable delay
* Driving Mode – Forward – prev
* Driving Mode – Forward – brake
* Driving Mode – Forward – only then brake on billets center position to ride backwards
* Strength of the brake in the middle of billets
Technical data of the configuration unit
* Input via four buttons
* Operation of a LCD display (two lines with 16 characters)
* Downloading the rule parameters for control of an infrared interface (wireless)
* Permanent saving the last regulator to download data
* Permanent storage of different control configurations (not yet implemented)
* Power supply via a 9V battery
* A configuration management unit ID – only its own control to respond to this ID. Tourism controller can be no coincidence reconfigured. C compiler of CCS
lcd_gostergeli_kumanda
Remote Controlled Toy Car schematic ccs c source code files alternative link:
Publication date: 2008/08/24 Tags: , , , ,
1 Comment “Remote Controlled Toy Car Project PIC16F877 PIC16F628
    8051 PS2 Keyboard with LCD Writing Text
    PS / 2 protocol used text via a keyboard microcontroller applications that perform printing text on the LCD
    The goal here Text via keyboard microcontroller to print text on the LCD. Through keyboard microcontroller contained in a code corresponding to each keystroke is generated. About scan code ASCII code is used as code corresponds microcontroller and LCD is switched to the found and processed. Circuit connectors are shown below:
    8051 PS2 Keyboard Circuit Diagram
