PIC16F877 Experiment Board Circuit PIC Programming PIC Tutorial Book
| Updated on July 28, 2024
A useful test development PIC16F877 circuit pcb printed circuit board design was quite nice small in size but has a lot of features. Serial RS232 connection, sensors, servos, PWM, I2C connector and so on. Experiment card with eagle schematics and PCB files are prepared. In addition, “the PIC Tutorial Programming” free ebook called shared.
Microchip PIC16F877 Development Board
pic-deneme-gelistirme-16F877-Platine
PIC16F877 Development Board Circuit
L293 * 2 Channel Motor Bridge
Up to 16 servos can be controlled (or a motor bridge and 12 servos)
Separate power supply for microcontroller, servos and motors
Port A as either analog or used for servos.
3 LEDs and a demo on A4
I2C and SPI, ICSP
LowDrop optional voltage regulator or standard 7805
Can monitor its own microcontroller-voltage
Source: goo.gl/eLm4 PIC16F877 Development Board circuit and Tutorial Alternative link:
Publication date: 2010/08/12 Tags: ,
1 Comment “PIC16F877 Experiment Board Circuit PIC Programming PIC Tutorial Book
    Development, Experiment Circuits Atmel AT89C51RB2 AT89C5131A
    Atmel AT89C51-series microcontrollers for RB2 and AT89C5131A summer programs that try to experiment with a variety of cards for AT89C51-RB-2, which carries the same features as the circuit usb-aided circuit instead of just usb rs232 connection. All circuits prepared with eagle pcb’s schema files and material lists.
    Atmel AT89C5131A-USB: 4 buttons (cut), 8 LED display, LCD-Display, 2 × 16, 8-bit analog-to-digital converter, additional hardware connections to the pins, SPI interface, RS-232 communication interface, USB Port connection
    AT89C51RB2 AT89C5131A Development
