Robot project PIC16F877 microcontroller used ARX34 AND ATX34 RF modules and remote kantrol can be 3 servo makanik run software ccs written in c receiver, transmitter section if our writers Aykut my brother “PIC16F628 with a 4-channel transceiver RF application” article sharing application’s also in the control circuit proteus ares isis owned and simulation, PCB’s in the drawing.
author by: Arda KILIÇ – thanks to those who contributed to preparing
ARX34 ATX34 connection diagram of the RF modules;
Robot project files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-17930.zip
Toy Car Modification Made Simple Robot Project ATtiny2313
Simple robot project ATtiny2313 microcontroller used robot body for a cheap remote controlled toy car is made up of the robot’s four sides LED sensors placed somewhere when it hit the back çekliy direction change somewhere else until you hit continues 🙂 motor drives the car as on the original circuit drive partition (sm6135w) used There is a simple transistor circuit .. schema, in addition to a distinct beauty of this pressure sensor circuit diagram drawings, source code through ATtiny2313 find. Also check ATtiny2313 floor designed as a simple set of experiments can use it in different projects, each floor of the circuit works
