Oscilloscope Circuit with MAX492 PIC16F877 Graphic LCD
| Updated on September 5, 2024
Oscilloscope circuit project pic16f877-20 (20 MHz) microcontroller based on X 1, x 10 entries MAX492 Rail-to-Rail Op Amp input via grilimi 5v indicator as 128 × 64 glcd (PG12864) graphic lcd. Oscilloscope circuit power supply 9v dc
The application schema, the circuit source assemly asm, hex codes for detailed description.
oscilloscope-circuit-osiloskop-devresi-128X64-pic16f877-glcd
graphic-lcd-oscilloscope-circuit-with-pic16f877-20p-max492
Source: http://elektron.uw.hu/
Publication date: 2011/03/15 Tags: , ,
1 Comment “Oscilloscope Circuit with MAX492 PIC16F877 Graphic LCD
    Solar Panel Battery MPPT Charger Circuit pic16f88
    Solar energy is quite busy these days, interest in the evaluation of solar panel running through the charging circuit, I hope useful contacts.
    MPPT solar panel charging circuit on the Board, 12Ah … pic16f88 microcontroller 40Ah-lead acid, SLA, AGM batteries rechargeable 12v Battery and you will use the information according to the current table has power over. The charging process will be fast switched to commissioning of the source codes for the pcb, hex, schema, assebly of materials etc. have the drawings
