Capacity meter circuit PIC16F873A
| Updated on August 3, 2019
Capacity meter circuit 5pF and 2600uf between the condenser capacity can gauge the pic16f873 microcontroller and a few passive element and the circuit formed values ​​of 2 × 16 LCD screen is displayed on the software assembly prepared by the source asm code description in the measurements performed on may be useful project ..
autorange-capacitance-meter
capacitance-meter-discharging-capacitor-fully
Source: http://webspace.webring.com/people/fd/dariuskrail20/PICCapMeter.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-17894.zip
Publication date: 2011/11/14 Tags: ,
1 Comment “Capacity meter circuit PIC16F873A
    Counter Circuits Jalv2 pic16f628
    Circuits PIC16F628 microcontrollers are based on the screening method using the program, the language is written with Jalv2. When the circuit board with resistors inside the blue frame on the right side, just because it was used to study the use of simulation will be healthy. Instead of an external crystal in the crystal circuits 16F628 internal oscillator is used. In practice there is no need to use crystal element
