PIC16F84 Multi Siren Sounds Circuit
| July 14, 2023 Updated
16 different alarm sound circuit, after running the simulation of the fourth line of dip switches in different positions can run by selecting the 4 × 4 = 16 different sound Remember to press the reset button at the end of each selection. Original ASM file is available.
Example PICmicro Sounds: Police, telephone, IEP, buzzer,laser, etc.
Siren Sounds Circuit Schematic
siren-devresi-150x150
PIC16F84 Siren Sounds circuit proteus simulation schematic pic assembly source code
Published: 2008/11/05 Tags: , , , ,
4 Comments “PIC16F84 Multi Siren Sounds Circuit
    PIC16F84 LCD Display LC Meter
    PIC16F84 LCD Display LC Meter circuit Box front waisted measure be careful when buying the box to cut the picture box paste it on top and falçata or drawing a knife then stop in the box bourdu to keep the four M3 screws and nuts, use Bordt USING the reader relays internal diode line is I’m a little late, I realized I did board relay leg reverse came first problem was that but in the scheme and BoardTM fix but I still protection diode I used the relay of different uses for kaldırmadım.pow source 12 Volt DC Jack (interior +) (outer portion of the Gnd)
  2. Mark WallisMark Wallis
    HI. Can I just check the configuration bits are as listed:
    WDT: enabled
    PWRTE: disabled
    OSC: RC (which values had you used?)
    Regards, Mark.
