PS2 mouse control PIC16F726 test circuit
| Updated on September 10, 2024
Maus PS2 mouse designed to test a circuit according to the movements led display beautiful works of various shapes can be removed pic16f726 microcontroller circuit is realized with software ps2 prepared by assembyl the connector was installed and operated according to a simple circuit.
ps2-maus-led-display-circuit-communications-routines-data-clock
ps2-konnektor-bred-board-devre-pic16f726-ps2-mous-test-circuit
Source: thevaportrail.com alternative link:
Publication date: 2011/07/17 Tags: ,
1 Comment “PS2 mouse control PIC16F726 test circuit
    PIC24F64GA002 Video Remote Environmental Monitoring ENC28J60 TCPIP stack
    Custom designed hardware, presented using the eligible Microchip 16-bit MCU PIC24F64GA002, has been developed for the Microchip design contest to implement a video based remote environmental monitoring system for use in critical areas. The design has incorporated an on-board video camera, battery back-up and a number of Microchip devices to obtain a comprehensive environmental monitor. The Ethernet interface is achieved with the Microchip ENC28J60 which is a Stand alone Ethernet controller with SPI interface. The temperature is measured with the Microchip MCP9800 which is an I2C based temperature measuring sensor. The Microchip 24LC16BT I2c based EEPROM has been used to store the user configurable high and low temperature set points as well as the point at which image differences will generate an alarm. DHCP has been used to obtain an IP address automatically from a DHCP server.
