Combination Lock Circuit PIC16F628 Hi Tech C
| Updated on July 27, 2024
@ Profahmet teacher previously had shared projects a combination lock on the hitech picc thought it would be a good example of programming with c language can be an example for people who can give limp and PCBs have drawings of the project’s source code.
elektronik-sifreli-kilit
Combination Lock Circuit User manual
# The default code is “1111” # (EEPROM microcontroller in nenaprogramovano first power supply)
# “New Code” old password “*” to change the code by typing a new code
# Enter the code: “Code” #
# Only four digit codes (current firmware) accept lock
# Enter, press “#” to serve as an Enter
# Button “*” is used to change the code
Even if the password is stored in the EEPROM is stored in the microcontroller is not affected by power outage
As a control element is used PIC16F628A microcontroller or an older type of PIC16F84A ( see paragraph below : mounting variants) . They are accompanied by the indication LEDs, transistors through the relay
The source is solved simply assumed DC voltage supply . At the entrance is a fine surge protection in the form Transil and insurance . Furthermore, there is a stabilizer 7805 in the classical circuit.
The output element is a relay that always correctly specified code changes state . Closed state is indicated by a green LED . If the relay is open off any indicator . This is because the device was originally designed for the control of small control panel via an impedance balanced loop and arming status – relay open – the required minimum order . For this application , there is a left and a resistor R3 ( typically 1k ) , which served as a balancing loop for the alarm system. If you want to use only the relay , it is possible to replace the resistor jumper. This is brought out to the terminal directly contact NO for free use ( subject to the maximum switching current and voltage).
Source: http://firma.puhy.cz/kodovy-zamek PIC16F628 Combination Lock Circuit Alternative link:
Publication date: 2010/08/03 Tags: , , ,
1 Comment “Combination Lock Circuit PIC16F628 Hi Tech C
    Telephone Transmitter Circuit FM
    FM transmitter circuit, but this circuit is generally used for music in a slightly different circuit parallel to the line connecting the phone conversation set can listen to the FM band. FM transmitter circuit does not require additional power required for operation of the energy received from the telephone line
