Picbasic aside, it is easy to write code for various circuits with the jal language, but it is difficult to find sufficient Turkish resources, there are few users, but many problems can be solved with sample applications, when the codes are examined, they can give new ideas.
The isis simulation files belonging to the circuit are jalv2 source code and lib files. The shift thickness and speed of the LEDs can be changed and the settings are kept in memory.
Hello Friends.. I have implemented an application with Jalv2.. I want to share it with you.. It can be used as desired..
Circuit Name: Black Lightning Effect with changeable shift thickness and speed and kept in memory
Compiler: Jalv2The program has been tested in Proteus.. You can find the circuit below with the necessary explanations and codes.. I have put the necessary library files in it for friends who want to make changes to the codes.. It is located in the Lib folder inside the drawer..
Good luck.. Friends..
King Rider circuit schematic code files:
Published: 2010/08/01 Tags: microchip projects, microcontroller projects, pic16f628 projects
PIC18F4550 USB Keyboard (buttons LCD)
Microchip PIC18 USB applications quite popular with the series project with PIC18F4550 usb keyboard would be a good example for many people.
I’ve never known USB issues after me pretty puzzling to others with the principles of simplicity, I share my project 18F.
There are 14 buttons pressed them ABCD keys 1-9,0 and prints. Meanwhile, the key pressed at 2 × 16 LCD Viewing. the computer recognizes the device as a keyboard hidden. In the link there, but the whole project isis usb keyboard does not work. I prepare the file isis scheme in terms of connectivity. Codes are written with protons.
