CNC Project on via a computer paralelport lpt with the various engine controls allows you to make a circuit on the circuit input and output sections terminals is done via the lpt 74HC244N integrated depending on the pcb printed circuit board design quite well circuit diagram pcb drawings resource asm hex code there.
CNC Interface circuit
If we look for the Web will find many options to build a system of drivers CNC, in my case I like the modular format, where on the one hand we have the drivers, who control the engines as the signals it receives from the PC, and the interface, that actually does more than communicate with the PC drivers, some people in one arm around plate, even omitting the smooth interface, is a matter of taste and practicality.
In this case then we will have interface on the one hand and on the other drivers, being the real objective of isolating the parallel port interface of the PC drivers, in this case using floodgates kind of buffers (74HC244), surely many will say it would do better with opto-isolator, may be so, but the availability of optos quick response here in arg is not very good, or are very expensive, besides taking care using minimum buffers is more adequate, and these are very fast.
Source: esteca55.com.ar CNC Control Interface with PIC12F629 and 74HC244N alternative link:
Publication date: 2008/05/10 Tags: microchip projects, microcontroller projects
0-25V 2.5A Digital Power Supply Circuit LCD Display PIC16F873P
Digital power supply circuit with microcontroller pic16f873p conducted and current sensing, power transistors (tip142) is used in the control LM324 op amp. LCD display showing information on the current and voltage source project pic code (asm, hex) and with eagle pcb files have drawn diagrams. For boxing writers have used an old AT power supply box.
PIC16F873 PICmicro Dijital Power Supply
