Three-Axis Stepper Motor Driver Circuit with PIC12C508
| Updated on July 8, 2023
From the computer’s parallel port 3 axis cnc stepper motor control circuit can be used for projects PIC12C508 microcontroller (3 pieces) lpt port connected to the output MOSFETs in there. PCB material list, diagrams, code’s documentation. Motor control drive circuit used with Mach3 CNC program.
3 Axis Stepper Motor Driver
pic12c508-3-axis-board-cnc-circuit-schema-motor-step
mje15003-3-axis-board-cnc-circuit-schema-motor-step
Source: hobbycnc.hu Three-Axis Stepper Motor Driver Circuit with PIC12C508 alternative link:
Publication date: 2008/05/10 Tags: ,
1 Comment “Three-Axis Stepper Motor Driver Circuit with PIC12C508
    CNC Control Interface with PIC12F629 and 74HC244N
    CNC Project on via a computer paralelport lpt with the various engine controls allows you to make a circuit on the circuit input and output sections terminals is done via the lpt 74HC244N integrated depending on the pcb printed circuit board design quite well circuit diagram pcb drawings resource asm hex code there.
