PImicroC Multi Calculator: PIC Programming a useful calculation program for people dealing with Timer, PWM, LCD character, USART, etc.. In my calculation you can do a lot of work for me soon so hopefully that will not require installation and free;)
Calculation means; Time Calculator, Time Helper, USART Calculator, Calculator EUSART, SERIAL IN / OUT Calculator, Calculator PWM, A / D Calculator, Comparator Vref, LCD Custom Character
Source: http://www.mister-e.org/pages/picmulticalcpag.html
PICmicro Multi Calculator
Publication date: 2008/03/16 Tags: electronics software tools
USB Battery Charger Circuit with PIC16F629
USB Battery Charger Circuit Pic16f629 microcontroller integrated with the computer’s USB port 1 100-1000 The AAA battery charging circuit charging time the battery current compared to 1-14 hours of battery is full time dual-color LED and buzzer and warning is given. Besleneeg from the USB port in the circuit diagram for the circuit in 7805 will use a 5 volt regulator IC that you do not want to use the USB port with an adapter 9v 12v going to use … 7805 should be installed .. USB battery charging circuit assembly prepared with the resources of the microcontroller software. Asm and. Hex file there.
PIC16F629 USB Battery Charger
