PIC12F629, PIC16F630, PIC16F84 microcontroller prepared with different control circuits available 3-8-10 Channel
Control projects have hex and asm code only 10 channels available in the command and control circuit pcb file. Check-in will use the PIC can control various devices by the control elements from the simplest relay circuits used in
IR Remote Control with PICmicro circuit files:
IR Remote Control Circuits with PICmicro
Publication date: 2008/01/12 Tags: microchip projects, microcontroller projects, pic assembly example
Computer Device Control with LPT Relay
LPT port of your computer using the simple and cheap 🙂 You can control various devices such as
three circuits have one ULN2803 Used a few passive components easily with the application can be made, but not isolated, the other two is enabled LPT Port from the isolated state opto Kubla made with 24 volts and 12 volts for the relay have two applications 24 Volt Relay Control Circuit 4N22 Opto Kubla’s Used other I applied in the past 12 volt control circuit and a circuit of a simple control program Source code of the program in Visual Basic 6 program gellistir If you have any information you may have
IR-Fernbedienungsschaltkreise mit PICmicro
Mikrocontroller PIC12F629, PIC16F630, PIC16F84, vorbereitet mit verschiedenen Steuerkreisen, verfügbar mit 3-8-10 Kanälen
Steuerprojekte haben hexadezimalen und asm-Code. In der Steuerplatinen-PCB-Datei sind nur 10 Kanäle verfügbar. Beim Einchecken kann der PIC verschiedene Geräte über die Bedienelemente aus den einfachsten in verwendeten Relaisschaltungen ansteuern
