Metronome electronic PIC 16F84 The draft submitted on this page and ‘found on the site www.htsoft.com, the software house that produces the compiler ANSI C for the PIC family of microcontrollers used in school. The management software provided as a demo for the compiler contains some errors in the values contained in the carrier digit [] that is used to decode BCD / 7 segments.
In addition, the part relating to the management of energy saving should be rewritten. Rules’ management SLEEP awakening by the state following the expiry of watch-dog on PIC 16C57, initially used for this project, are different from those provided on PIC 16F84, namely:
PIC 16C57: the expiration of a watch-dog timer with the processor in the state of sleep causes, however, reset the processor; PIC 16F84: the expiration of a watch-dog timer with the processor in the state of sleep makes the processor run the next statement that it has put in mode ‘sleep asm ( “sleep”);
PIC16F84 Metronome Circuit
Publication date: 2008/08/29 Tags: hi tech c examples, microchip projects, microcontroller projects, pic16f84 projects
Sine Wave Output MOSFET 40W Amplifier Circuit
8Ω + / – 35V – 40W sinus plate amplifier power. Jeden kanal. One channel. The layout is based on symmetrical arrangement of input from current and balanced agreement, control Contains DC Servo system for the precise determination of zero output. The degree of current contains transistors bipolarne. It voltage to + /-24V and + /-39V. Of course, when other elements of other possible supply voltage.
Sine Wave Amplifier Circuit
