PCB Cutting Machine Sewing Machine Modification
| Updated on April 24, 2016
It’s an interesting project I’ve seen in a project that is usually done with electric drills handmade shared a sawhorse; Dremel 4000 handmade sawhorse, Proxxon Made by reference to the sawhorse and circular saw for cutting PCB Assembly
Sewing machine tuning, the author attached to the needle section of the machine and have mounted the jigsaw in this way, PCB cutting are doing their job.
dikis-makinesi-modifiye
source: grix.it
Publication date: 2016/04/23 Tags:
2 Comments “PCB Cutting Machine Sewing Machine Modification
    Upgrade The Output Power MOSFET LM2576 LM2575
    Previously LM2575 (1 amp), and the LM2576 (3 amps) switching regulator ICS sharing about applications that have been LM2575, LM2575 high power mosfet to increase the output current by adding the received power regulator circuits of this type are usually integrated in the upgrade I wanted to share, it’s no wonder.
    Note: without pictures I don’t share the projects I made, but this application, with the exception of when you’re in a higher power, it’s worth a try 🙂 also, this circuit is the main source of Elektor
    LM2575 Adjustable DC-DC converter
    PWB-Schneidemaschine Nähmaschine, Änderung
    Es ist ein Interessantes Projekt, das ich gesehen habe in einem Projekt befinden, erfolgt in der Regel mit elektrischen Bohrern handgemachtes shared a sawhorse; Dremel 4000 handgemachte sawhorse, Proxxon erfolgt unter Bezugnahme auf die sawhorse und eine Kreissäge für das schneiden pcb-Versammlung
    Nähmaschine-tuning, dem Autor angebracht, um die Nadel Teil der Maschine und dem Einbau der Stichsäge in dieser Art und Weise, in PCB schneiden machen Ihren job.
