Toy car remote control Circuit PIC18F452 PIC16F628
| Updated on July 26, 2024
Share Article Sharing section of the project as a okuru thanks to an implementation project okuru sender. Circuit PIC18F452 and PIC16F628 microcontrollers based on the
oyuncak-araba-kumanda-120x120 oyuncak-araba-kumanda-ir-led-mod-120x120 oyuncak-araba-kumanda-ir-alici-verici-pic16f628-pil-devre-120x120 oyuncak-araba-kumanda-ir-alici-verici-pic18f452-120x120
This car speed control Forward-back and right-left turn at the desired angle has the features. Isis rear engine speed control forward and backward in the program folder in the sample is transferred. Lm555 the 38 Khz circuit diagram used on the site from the website alınmıştır.ancak 10K potentiometer 22K potentiometer is used instead. Receiver and Transmitter unnecessary rows in the program can edit the self-liking.
Based on the transmitter BC547 LM555 wasted in the oval No. 3 in the foot signal with a 22K potentiometer should be set to 38 Khz. Right-left and rear of the engine maximum-minimum return imide donor program at the desired values ​​can be adjusted according to each car. I’ve done these settings works just fine in the car.
Remote control toy car project files (proteus isis, ares PCB, c software):
Publication date: 2010/08/01 Tags: , ,
1 Comment “Toy car remote control Circuit PIC18F452 PIC16F628
    Oscilloscope to Test Components Circuit
    Oscilloscope with the component that facilitates a practical test quite simple but important circuit switched wanted to bet most of us already have barely been oscilloscope at least from all the opportunities I faydalanal
    Oscilloscope with the material test subject was shared by picproje.org forums a.zorb and useful information about the files belonging to the project’s
