Simple robot project ATtiny2313 microcontroller used robot body for a cheap remote controlled toy car is made up of the robot’s four sides LED sensors placed somewhere when it hit the back çekliy direction change somewhere else until you hit continues 🙂 motor drives the car as on the original circuit drive partition (sm6135w) used There is a simple transistor circuit .. schema, in addition to a distinct beauty of this pressure sensor circuit diagram drawings, source code through ATtiny2313 find. Also check ATtiny2313 floor designed as a simple set of experiments can use it in different projects, each floor of the circuit works ..
Source: http://roboforum.ru/forum10/topic9762.html
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-17899.zip
Publication date: 2011/11/14 Tags: avr project, microcontroller projects
Capacity meter circuit PIC16F873A
Capacity meter circuit 5pF and 2600uf between the condenser capacity can gauge the pic16f873 microcontroller and a few passive element and the circuit formed values of 2 × 16 LCD screen is displayed on the software assembly prepared by the source asm code description in the measurements performed on may be useful project ..
