MSP430F5438 Development Board PCB MSP430 Example
| July 31, 2024 Updated
Texas Instruments MSP430F5438 MCU prepared for the trial development kit (MSP-EXP430F5438) belongs eagle pcb schematics, gerber files and sample application code
MSP-EXP430F5438-eagle-pcb
msp-exp430f5438-16-Bit-Ultra-Low-Power-Microcontroller
MSP430F5438 experiment kit MSP430 Example
The MSP430F5438 Experimenter Board (MSP-EXP430F5438) is a development platform for the latest generation MSP430 MCUs. It features a 100-pin socket which supports the MSP430F5438 and other devices with similar pinout.
* 100-pin socket for MSP430F5438
* Power Supply sources: USB, FET, 2x AA batteries
* Digital I/O Pins: 34
* Accessible analog inputs (12-bit ADC): 5
* PWM outputs: 12
* Flash Memory (MSP430F5438): 256KB
* RAM (MSP430F5438): 16KB
* Clock Speed (MSP430F5438): 18MHz
* Communication (MSP430F5438):
o 4x UART/LIN/IrDA/SPI
o 4x I2C/SPI
* 5-position joystick (up, down, left, right, push down)
* 2 push buttons
* 2 LEDs
* 138×110 grayscale, dot-matrix LCD
* 3-Axis Accelerometer (ADXL330)
* Microphone (Amplified by TLV2760)
* 3.5mm audio output jack (Features TPA301, 350mW Mono Audio Power Amplifier)
* Support for TI Low Power RF Wireless Evaluation Modules and eZ430-RF2500T. Currently supported modules:
o CC1100/CC1101EMK – Sub-1GHz radio
o CC2500EMK – 2.4 GHz radio
o CC2420/CC2430EMK – 2.4 GHz 802.15.4 radio
o CC2520/CC2530EMK – 2.4 GHz 802.15.4 radio
* USB connectivity for data transfer
* JTAG header for real-time, in-system programming
MSP430-EXP430F5438 kit pcb sample files:
Published: 2010/10/22 Tags: ,
1 Comment “MSP430F5438 Development Board PCB MSP430 Example
    Mini cannon Top Handmade Throws
    Or treatment with CNC lathes made ​​probably throws a little ball of yellow color and is very small but quite cute test images show what appears to be strong enough 🙂
