Nokia 5110 LCD with MSP430 microcontroller needed to use the library and MSP430 sample application code 6 x 8 font files. Codes prepared by the C language.
main.c, msp430\nokia_5110.c, msp430\nokia_5110.h, nokia5110.ewd, nokia5110.ewp, bmp_pixel.h, nokia5110.d43, msp430\Debug\Obj\main.r43, msp430\Debug\Obj\nokia5110.pbd, msp430\Debug\Obj\nokia_5110.r43, english_6x8_pixel.h chinese_string_pixel.h
MSP430 Application all files:
MSP430 Application Code LCD library Nokia5110
Published: 2010/10/22 Tags: microcontroller projects, msp430 projects
Started with the MSP430 Programming Simple Test Circuit
Review of Texas Instruments MSP430 Series now from our country slowly began to use Texas Instruments products firm is working for me in abundance on this MCU project, circuit, I will try to share information.
Trial MSP430F110IDW circuit or participants can use for MSP430F120IDW. Software can test you can observe the work. MSP430 peripherals etc.. on the port used for pcb pad attached to certain connections can be used for a variety of other empty pad on the PCB board made a kind of bred bred small board instead sold to piyadas would be more useful if installed. Separate the various modules (LEDs, buttons, etc.) are able to develop and test circuit
Started MSP430 Programming Test Circuit
