Hi all, I have made this request before my article combination lock circuit. As you know, on the internet, various controllers (atmel, pic, etc.) are made with a lot of combination lock implementation. When the implementation of a simple combination lock, similar to me. As the application’s main feature is that it is made of a printed circuit board. In addition to this, due to a design, just 3/4 pieces on a cable you can program and debug the circuit using the msp430′a. In addition, during the study and use of flash memory with the msp430 keypad, write, read operations are functions that might be an example.
MSP430 Design with Combination Lock
As we commonly use MSP430 Launchpad with various MSP430 applications can do by connecting additional equipment . In addition to this, we develop a product , or an assignment, project , etc. needed to make printed circuit boards is inevitable. Compared to other MSP430 microcontroller on the Internet by none so much pressure circuit applications . That’s why I felt the need to share this application due .
Each microcontroller due to a few differences in the structural design of printed circuit boards can vary . For example, the most important element for MSP430 programming circuit and the supply voltage is 3.3V . Other microcontrollers made by paying attention to them MSP430 applications in printing circuit can be implemented. This , above all, those described printed circuit design and PCB drawings are required to be knowledgeable about the program . This application of the printed circuit Proteus / Area program ( v7.7 ) is designed with .
Combination Lock Application On The Printed Circuit Board Design
Application C code and proteus ares pcb, isis simulation files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22114.zip
Published: 2013/09/22 Tags: microcontroller projects, msp430 projects
TDA7294 Subwoofer Amplifier Circuit
Guys Hi, I come to you with a new circuit. To tell you from the beginning, this circuit is developed with requests from me. These are simple, low-cost, practical, small size and a subwoofer amplifier for a standard home environment was sufficient.I think it’s just been such a circuit.Amplifier power is flawed TDA7294 with max. 70W RMS 5% distortion.Of course, some of this power to datasheette we need to table on page 3.
Tastatur-Kombination Schloss Mit MSP430 Launchpad
Hi alle, ich habe diese Anfrage vor meiner Artikel-Zahlenschloss-Schaltung. Wie Sie wissen, auf das internet, verschiedene Controller (atmel, pic, etc.) mit viel Kombination-lock-Implementierung. Wenn die Implementierung einer einfachen Zahlenschloss, ähnlich wie mir. Die Anwendung ist wichtigstes Merkmal ist, dass es ist aus einer gedruckten Leiterplatte. Zusätzlich zu diesem, wegen einem design, nur 3/4 Stücke auf ein Kabel kann man Programmieren und Debuggen die Schaltung mit dem msp430 ‘ a. Darüber hinaus, während der Studie und die Verwendung von flash-Speicher mit dem msp430-Tastatur, schreib -, lese-Operationen sind Funktionen, die möglicherweise ein Beispiel sein.
