Sumo Robot Project PIC16F877 Control Circuit L293D
| August 20, 2024 Updated
Mini sumo robot design is very stylish robot pic16f877 microcontroller used in motor driver for the l293d kullanılmş software crafted with the C language. Mini densede very detailed all of the resources that are shared with a Sumo robot project also robot contest opponents out of the runway:)
SUMO-ROBOT-features
Size 9.9cm(W) x 9.9cm(L) x 6.8cm(H)
weight 498 gr
Microcontroller MCU PIC16F877-20/SP with 16 MHZ Crystal
8K ROM 368 Byte RAM
Programming
Language
C
Motor 2 Lego 350 RPM 9 volt gear motor
Motor driver
chip
L293D
Speed control Software-PRM (Pulse Rate of Modulator) EMF feedback
tires 2 pcs 30.4 mm Lego tires
wheels Made of stainless steel wheels
Driver systems Lego motor ve shaft
Speed 36 cm/sec
Power 450 grams (wheels spinning)
Power supply 2 pcs. 9v alkaline batteries
Motor current 60mA crusing, 400 mA pushing
Sensors Two reflective infrared sensor for the detection of edges
active IR
Tele-metri Connection for external transmitter
Linx TXM-418-RM (9600 baud 418 MHZ)
Robot Project Tests
sumo-robot-robots-projekt-l293-motor-kontrol-robotlar-1
sumo-robot-yarismasi-robotlar-yarisiyor-2
sumo-robot-mini-mikrocontroller-delta-force-robotic-rally-3
robot-devresi-robors-circuits-4
sumo-robotun-mekanik-saft-lastik-tekerlek-motorlari-5
Source: http://www.wa4dsy.net/robot/deltaforce/
Published: 2011/01/10 Tags: , ,
1 Comment “Sumo Robot Project PIC16F877 Control Circuit L293D
    Six-Legged Basic Stamp2 Spider Robot Project
    Spider robot mechanically quite a detailed project control system based on pic microcontroller Basic Stamp 2 module is provided with circuit 7.2 Volt NiCad batteries in addition to the fed with the RC5 remote support, there is a variety of sound effects Robot circuit all sources (codes, orcad schema etc) shared a robotic jobs for people dealing with an enlightened project
