Free Toroid Core Calculator Program
| Updated on August 22, 2023
Program T-type ferromagnetic and non more medically for transformer calculations you can do (FERROXCUBE, Unknown Cores, Air Cores, Iron Powder T, Ferrite FT, Sifferit) mini ring core calculator program is free.
Also the “Tools” section includes a variety of tools
  • AL and Permeability
  • Resonant Circuit
  • Cu Resistance
  • Metric Conversion
Core Calculator
core-calculator-bobin-ferit-trafo-hesaplama
al-and-permeability-resonant-circuit-cu-resistance-metric-conversion
Source: dl5swb.de Free Toroid Core Calculator Program alternative link:
Publication date: 2009/09/24 Tags:
1 Comment “Free Toroid Core Calculator Program
    400W Power Amplifier Module Circuit 2SA1943 2SC5200
    The Far East quite a popular hi fi BJT transistor amplifier module for full power output transistors 4 2SC 5200 and 2S 1943 should be tested one at each used test voltage +-35v accordingly, the power will be lower for full power supply voltage pretty high, build and test stages be careful of capacitors and transistors link circuit voltage without checking whether it is correct to give.
    Maximum supply voltage + / – 95V.
    Output power 255W RMS 8 Ohm speaker with 4 ohm speakers with 400W RMS
    Frequency Response 20Hz – 20Khz
    Input Sensitivity 1.25V RMS
    Input impedance 39 pounds. ohms.
