In this work, using a PIC16F877 Hello friends and I created a volt meter with single-channel ADCs have. Similar programs for use with the volt meter microcar able to find the opportunity to examine what I thought. At a later time, I will publish the project again in a state of functional
/* VOLT METER APPLICATION WITH ADC JANUARY 2010 KOCAELİ UNIVERSITY TEF ELECTRICITY PIC877A microprocessor 4mhz crystal */ unsigned char volt; unsigned int volt_read; unsigned int i; char *text; long tlong; void main() { INTCON = 0; // All interrupts canceled Lcd_Init(&PORTB); // Lcd_Init prepared for PORTB LCD LCD_Cmd(LCD_CURSOR_OFF); // LCD cursor closed LCD_Cmd(LCD_CLEAR); // Deleted to avoid random characters on the LCD Lcd_Out(1,6,"KOU TEF"); // 1st line6. information has been written to the character ADCON1 = 0x82; // ADC settings TRISA = 0xFF; // PORT A is logged delay_ms(500); text = "VOLT: "; // DISCLOSURE TEXTS while (1) { volt_read = ADC_read(2); // ADC 2 channels read LCD_Out(2,1,text); // print TEXT to the screen tlong = (long)volt_oku * 5000; // read volts converted to millivolts tlong = tlong / 1022; // Converting milli volts to volts volts = tlong / 1000; // Assigning the value X.,.. LCD_Chr(2,8,48+volts); // X value line 2 is printed from 8th character volt = (tlong / 100)10%; // Assigning .X,.. LCD_Chr_CP(48+volts); // X value is printed from the cursor position in line 2 LCD_Chr_CP('.'); volt = (tlong / 10) 10%; // 0.1 volts d LCD_Chr_CP(48+volts); // is printed from the cursor position in line 2 volts = tlong 10%; // 0.01 volts LCD_Chr_CP(48+volts); // is printed from the cursor position in line 2 LCD_Chr_CP('V'); // V unit is added to the result obtained. delay_ms(1); // waiting for 1ms for loop instabilities } }//~!
MicroC ADC Example code and pic16f877 circuit proteus isis schematic files:
PIC16F877 ADC Volt Meter Circuit MicroC Example
Published: 2010/01/30 Tags: microchip projects, microcontroller projects, pic16f877 projects
6V 4AH Fake Battery
Previously, “Fastening Capacitor” I reported the issue through 6800uF 2200uF electrolytic capacitor was coming 🙂 is now a more advanced level three papers: Dr. Ramming tamirci_erh battery in the incident at the beginning of the history of a friend of my brother.
