Based on the DC-DC converter circuit MC-34063, it can provide integrated 500 milliamper power without extra power amplification, but this value changes according to the output voltage, the operating frequency of which is determined as 70 kHz with the C6 capacitor, you can adjust the output voltage with the r4 5k trimpot. The materials used are smd small type if you want normal materials You can make your circuit with
Input voltage: 5Volt 24volt
Output voltage: 3volt – 12volt (adjustable)
Output current: 500mA max
Current consumption (no load): 10 mA
Efficiency: 85% max
PCB Size: 42 x 27 mm
MC34063 Step Down Converter Circuit
Switching regulators are more energy efficient, require as a linear regulator due to the low power dissipation, less Space and can be particularly compact Power supply module to devices many tasks solve. Super compact can be the task with SMD technology solve. Our step-down converter is within the input range from 5 V to 24 V can be used and gives an adjustable output voltage of 3 V to 12 V at a maximum current capacity of 0.5A.
If one wishes to supply a stabilized voltage realize, then either often to Linear regulator. However, particularly in larger differences between the input and Output voltage, the resulting Loss performance significantly. This reduces at Battery or the battery is not only unnecessary the life of the energy donor, but also raises thermal, and when a heat sink is required, Space problems in the Device on. after all “Generates” a Such a linear regulator, when, for example, supply with 12 V and will provide 3V should a power loss of 4.5 W (at a Output current of 0.5 A), which as heat be dissipated needs.
source http://www.elv-downloads.de/service/manual /SDW1/SDW1_KM_G_050110.pdf MC34063 SMD Step Down converter Circuit 3V 12V Adjustable schematic, pcb files alternative link:
Published: 2009/03/23 Tags: dc dc converter circuit, power electronic projects
LM2575 Switched Lithium-Polymer Charging Circuit
For the battery charging circuit connected in series three “lithium polymer” LiPo batteries switched (switch mode) as fast as can be recharged.
3 of series-connected batteries rechargeable S1 segment with a key charging current 350-milliampere 530-milliampere 720-milliamp-1000-milliampere between can be selected charging status LEDs observations can model, model, robot works and of persons engaged useful to a circuit
