DC to DC Converter Adjustable CMOS Step-Up Switching regulator MAX643 circuit made with integrated MOSFETs supported by irf540 power output increased 45 kHz operating frequency of the circuit used in the circuit 0.8mm wire on the coil ring toroidal core 40 to be wound round
MAX643 DC DC Converter
To load parcels from 3 cells or polymer lithium ion battery charger using economic presented on this site (chargers for Lithium Polimery) it is necessary to have an input voltage of at least 16 volts.
Unfortunately, the source field of energy available is usually a 12 volt battery. I wanted then to design and implement this circuit voltage switching lift from 12 to 16.5 volts for everyone to use it to the field without problems. The project is based on an integrated Maxim, a MAX643 that with very few external components to achieve lift current tensions even for a few amperes.
In a nutshell goes to the mosfet and nell’induttore periodically conduct a current flows. It is therefore stored nell’induttore a certain amount of energy. When the mosfet does not lead to more tension dell’induttore leaders abruptly reversed making the mosfet drain of more positive formats. The current then through shottky 1N5822 diode loads the condenser C2.
For each cycle, therefore, the voltage on C2 salt until the MAX643 through partitore resistive composed of R3, R4a and R4b detects a value exceeding a certain threshold on foot VFB. THE mosfet at this point cease to go in periodically conduct and the output voltage begins to fall for the absorption of cargo and the loss of capacitor until the voltage on VFB falls below the threshold. At this point the mosfet begins again to work at a frequency of 45 kHz with time about opening gate approximately 11 usec.
input (12.2 volt, 260 ma) | output (16.5 volt, 160 ma) | eff = 82% |
input (12.3 volt, 390 ma) | output (16.5 volt, 250 ma) | eff = 85% |
input (12.3 volt, 570 ma) | output (16.4 volt, 360 ma) | eff = 84% |
input (12.3 volt, 1100 ma) | output (16.4 volt, 630 ma) | eff = 76% |
input (12.2 volt, 1200 ma) | output (16.2 volt, 740 ma) | eff = 82% |
input (12.2 volt, 1280 ma) | output (16.2 volt, 800 ma) | eff = 83% |
input (12.2 volt, 1365 ma) | output (16.2 volt, 860 ma) | eff = 84% |
input (12.2 volt, 1450 ma) | output (16.2 volt, 910 ma) | eff = 83% |
input (12.2 volt, 1490 ma) | output (16.2 volt, 930 ma) | eff = 83% |
As you can see in the charger position, all switches absorb 15.1 Watts, providing only 18.2 Watts with the circuit placed for maximum current. In these conditions the test is cold even at the current maximum of the diode and inductor. So the circuit can provide more current load at 1 Amp, but keep in mind that the inductor is designed for 1.5 Amps with a peak of 3 Amps and the performance is likely to degrade with increasing current.
Obviously, using a heatsink improves things even if the circuit is kept in function for a long time. It is important to use a 1N5822 shottky diode for 3 Amps, otherwise the circuit will be inefficient and hot.
Source: http://www.baronerosso.net/Articolo139-page2.html 12V to 16V DC DC Converter Circuit MAX643 sch pcb Alternative link:
Publication date: 2008/03/02 Tags: dc dc converter circuit, power electronic projects
PIC16F876 PWM Motor Speed Control
CCS PCM compiler pic16f876 microcontroller circuit prepared with software installed on the PIC hex output FETs are driven IRL1004 MOSFET PWM frequency of 10 kHz with the engine. Prepared with eagle pcb circuit and printed circuit board file source software.
12 V bis 16 V DC DC-Wandlerschaltung MAX643
Einstellbarer CMOS-Hochsetzsteller mit DC / DC-Wandler, MAX643-Schaltung, hergestellt mit integrierten MOSFETs, die von der IRF540-Ausgangsleistung unterstützt werden, erhöhte die Betriebsfrequenz von 45 kHz der Schaltung, die in dem 0,8-mm-Draht auf dem Spulenring-Ringkern 40 verwendet wird, der gewickelt werden soll
MAX643 DC DC Wandler
Um Pakete von 3-Zellen- oder Polymer-Lithium-Ionen-Batterieladegeräten unter Verwendung der auf dieser Website vorgestellten wirtschaftlichen (Ladegeräte für Lithium-Polimery) zu laden, ist eine Eingangsspannung von mindestens 16 Volt erforderlich.
Leider ist das zur Verfügung stehende Energiefeld normalerweise eine 12-Volt-Batterie. Ich wollte diesen Schaltungsspannungs-Schalthub von 12 auf 16,5 Volt entwerfen und implementieren, damit jeder ihn problemlos vor Ort einsetzen kann. Das Projekt basiert auf einem integrierten Maxim, einem MAX643, der mit sehr wenigen externen Bauteilen Hubstromspannungen auch bei wenigen Ampere erreicht.
Auf den Punkt gebracht geht zum Mosfet und nell’induttore regelmäßig ein Stromfluss. Es wird daher nell in einer bestimmten Menge an Energie gespeichert. Wenn der Mosfet nicht zu mehr Spannung führt, kehren die Marktführer abrupt um und lassen den Mosfet von positiveren Formaten abtropfen. Der Strom, der dann durch die Schottky-Diode 1N5822 fließt, belastet den Kondensator C2. Für jeden Zyklus detektiert daher die Spannung an C2-Salz, bis der MAX643 durch einen Teilwiderstand aus R3, R4a und R4b besteht, einen Wert, der eine bestimmte Schwelle an Fuß VFB überschreitet. Das Mosfet hört an diesem Punkt auf, periodisch zu leiten, und die Ausgangsspannung beginnt zu fallen, um Ladung aufzunehmen und den Kondensator zu verlieren, bis die Spannung an VFB unter den Schwellenwert fällt. Zu diesem Zeitpunkt beginnt der Mosfet wieder mit einer Frequenz von 45 kHz mit einer Zeit von etwa 11 usec, um das Tor zu öffnen.
