CCS C Matrix LED Display Snake Game Circuit PIC16F877 Microcontroller
| Updated on October 24, 2023
Snake game with matrix LED display indicator The software based on the PIC16F877 microcontroller was prepared with CCS C, the game is played with buttons on the matrix LED display indicator. The application was delivered from the Project Article Sharing section. Thanks to the people who sent the files and prepared the application.
CCS C Snake Game Circuit Test
A snake game prepared with PIC16f877. The snake is controlled with 4 buttons. It was programmed with CCS C.
A list of materials :
2 common anode 3 mm 7×5 matrix display
5 buttons
5 10k resistors
1 piece 4mhz crystal
1pc PIC16F877
Note: If you want to use a common cathode display in the circuit, you need to make some changes in the codes. The column selection function should be rearranged and the “~” sign in front of the information sent to port C by being reversed with “~” should be removed, that is, the information should be sent without being reversed.
source: recaisinekli.com Matrix LED display snake game application files (source ccs c, hex codes and proteus ares pcb circuit diagram file:
Publication date: 2010/05/03 Tags: , ,
1 Comment “CCS C Matrix LED Display Snake Game Circuit PIC16F877 Microcontroller
    4-Channel RF Transceiver Circuit with PIC16F628 Application
    The aim of the application circuit to consolidate the operation of the transmitter and receiver circuits. Our circuit consists of two separate circuit. 1st half 2nd half transmitter receiver circuit. The transmitter circuit 16F628, hibirit transmitter, 4-way dip switch. Receiver circuit 16F628, buyers of hybrid, 4 led.devre our 4 channel RF transmitter and receiver circuit. The number of channels can be increased by hardware and software.
    In 150 meters in open space are working smoothly. 50 meters closed area is working smoothly.
