LPC1102 ARM WLCSP 16 to DIP PCB
| Updated on August 3, 2019
@ Erhan my brother as a gift a few LPC1102 ARM have come, but in the market these tiny chip to use the inverter board (head board) do not get it right itself on the internet, sharing a lot has made me a contribution I get visibly pleased inverter board to do the job I took on the scrap laminate I barely with 3 Total PCBs was the last work 🙂 veteran was able to remove the repair does not work than do
lpc1102
@ Erhan brother first drawing Proteus ares made ​​with but ares printouts in the middle of the pads routes between the stickers while I sprint layout drawing with pasted in a printout was not a problem but the room millimeter making a mistake was therefore my drawings did not work in last picproj on the forums on the issue requests made ​​more professional of the members of the drawings prepared with a program prepared by @ mozkan87 posted his drawings has caused a problem in itself, thank you
lpc1102-header-pcb
lpc1102-header-pcb-arm-kart
PCB drawings (all):
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16469.zip
Publication date: 2011/10/01 Tags: ,
1 Comment “LPC1102 ARM WLCSP 16 to DIP PCB
    PIC18F4520 Unipolar Stepper Motor Driver Circuit
    Unipolar stepper motor driver circuit lcd graphics display control PIC18F4520 GLCD with WG12864B is provided. To the use of MOSFETs in the output irfz44 12-24 volts engines can take up to 4.5 amps. Take the necessary conditions are determined by the Menu button shape, flow and temperature settings can be made. CCS C Software with source code prepared, simulation isis, ares PCBs have all the resources.
