200Watt LME49810 Amplifier Circuit MJE15033 MJE15032 Transistors
| Updated on September 4, 2024
200w amplifier transistor amplifier circuit according to other more advanced. LME49810 200V founded on the integrated output amplifier integrated in the drive MJE15032, MJE15033 power transistors used.
The operation voltage of + -53 volts DC Circuit symmetrical 4ohm speaker with 8 ohm speakers with full power 100w power can give. Frequency Response: 7-140000 Hz-3dB Harmonic Distortion: 0.06% at 1kHz 200W; 200W 10kHz 0.054%, Inter modulation distortion: 0.26% 100W / 80 7 kHz
lme49810-200v-audio-power-amplifier-driver-baker-clamp
Source: zosilnovace.eu Alternative link:
Publication date: 2011/01/28 Tags: ,
1 Comment “200Watt LME49810 Amplifier Circuit MJE15033 MJE15032 Transistors
