LED VU Meter Circuit LM3916 17LED
| Updated on September 8, 2024
VU meter circuit 2 Dot / Bar Display driver lm3916 used the audio Gisira upgrades in 1 for TL072 op amp has my voice according to the severity of 17 LEDs flashing audio inputs in addition to the 100k potentiometer connecting the LEDs burning level, you can set. 12v dc circuit is working with VU meters.
lm3916-vumetre-devresi-vumeter-circuit-vu-led-leds
Source: habrahabr.ru alternative link:
Publication date: 2011/06/07 Tags: ,
1 Comment “LED VU Meter Circuit LM3916 17LED
    Microcontroller 8052 8051 Projects Code Library
    Following the 8052, 8051 how much use I do not know, but quite a large code library 8051 8052 projects, 8052 8051 circuit and a lot more applications where a rşiv share wanted additional Linux software ISP programmer with the transferor’s.
    There are about 250 files “codelib.htm” file and can be accessed by clicking on the links to be used without internet files “codelib.htm” file set
