Hello electronics lovers ..
Course is always good to give a breath between the short. LED signage and LED together this short animation of a program can be useful to those dealing with the isis schematic and printed circuit board hexkod I’m sending.
Led to animate its function will be useful for those who use a animaskart. In a well designed frame animation cards are available rotate feature or design my own card that I do not have this feature, but this feature is available for our advertisers using cards or hobby purposes it would be useful to regulate the LED animation.
Application files (isis schema, ares pcb, hex) :
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16054.zip
Published: 2011/08/27 Tags: microchip projects, microcontroller projects
Class D Amplifier Circuits
Class D amp circuits usually bass, a subwoofer is used in practice despite being small in size can offer very high power. There are 3 pieces of 300-watt Class D amplifier circuit ir2104 ir2110 drive MOSFETs irfb23n15d 900 watt 1200 watt amplifier tlp621 driver MOSFETs irfp3415 the ir2110s irfb52n15c 300W Class D amp Circuit, 900W Class D amp Circuit, 1200W Class D amp Circuit
