Which meant my mind for a while to do but I think the new 20W Halogens in the bathroom that led from their place and occur at the end of SMD5050 I wanted to share the spotlight.
Each of the light is nice, although certain Halogens, heat, and power consumption is high. Also will be the closest, however, as the difference of the angle (110-120 degrees) with LEDs SMD5050 LED daytime light I did.
LED Lamp circuit
In fact I’m thinking with 220V, but mold etc the halogen transformer because I don’t want to deal with in a very short time, my old Sony CD player from the first hand I said If I could take the adapter box blank. I used a 7812 with a simple leveling, LED adapter, if they have, Of course, can also be used.
After I bought the iron for heating it on the stove topper and a plaque egeleyer to fit into the slot. Slot fully compatible to standard Halogens.
Finally, usually 3 LEDs are cool, but I preferred 4 U and 2R2 resistors with more long-lasting the current I to be set. Preferences vary, but still no resistance should not be used
SMD5050 Led lamp pcb files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25470.zip
Publication date: 2016/04/23 Tags: led projects, simple circuit projects
Electronic Circuit Diagrams Part-2
Most of the comments shared with a lot of various electronic circuit diagrams simple structure can be easily implemented with less material on board is the circuit board you can experiment and bred
LED Strahler Leuchte Lampe SMD5050
Was bedeutete, dass mein Verstand für eine Weile zu tun, aber ich denke, die neue 20W Halogenen in das Badezimmer führte von Ihrem Platz und treten am Ende SMD5050 ich wollte das spotlight.
Jedes Licht ist schön, obwohl bestimmte Halogen -, Wärme-und Stromverbrauch ist hoch. Auch am nächsten, aber, wie die Differenz der Winkel (110-120 Grad) mit LED SMD5050 LED-Tagfahrlicht habe ich.
