Handmade projection applications that is still extremely popular very popular. Lighting is very important to be clear of the projection lamps generally used 12v led technology spread rapidly falling prices of the handmade projection has increased the use of LEDs for lighting in
The following placements in completed projects can inspire projections photos
Handmade Led Projection
Published: 2010/10/22 Tags: led projects
Stereo 35W Amplifier Circuit TDA7375
TDA7375 35w per channel with 4 Ω speaker power can give. The Amplifier project has two versions one single integrated stereo 2 × 35 watts while the other two circuits on a single printed circuit TDA7375 4 × 35 watts able to work with a single source supply can use in your car. PCB files, PDFs and protel format.
In addition to the various ways of integrating’s 4x17W or 2 +1 if you like you can use the TDA7375 datasheet file as given in the diagram.
TDA7375 Amplifier Circuit
